What graphic card?
What is the best grapic card i can get for my pc?
I have a amd a10 6800k cpu
the graphic card i have now is a XFX Radeon Hd 7790
My power supply is a Cooler Master b600 600 watt power supply
Hmm, an APU gaming system is a bit of a weird gaming rig. While it's a budget build, in order for one to take full adavantage of it's capability you have to have 2400mhz ram, which are expensive! If you can't afford to upgrade to a 2400mhz ram, why not just buy a GPU that will be well suited for your processor.
Check out Nvidea's GTX 750ti, or AMD's R9 270(x). I know AMD's R9 270(x) has been officially supported by the A10 7000s but I'm not so sure with the A10 6000s, any card higher than these two and your CPU would be bottleneck-ing the GPU.
it was a budget build pc, spendt around 1134 $ on my pc.
but tnx for the advice , also i have overclocked my ram to 2133 mhz
the grapich card i have now works really well on my pc, i get 30-40 fps on farcry 3 on ultra
and 70-80 on battlefield 4 on ultra
that performance seems pretty reasonable, I don't see a reason to upgrade.
I think Mantle is doing most of the work on BF4. :) Good guy Mantle.
that is without mantle, mantle gives me 2 fps
well the reason i want to upgrade is because i want MORE!!!, i am impressed with my system but i feel like i can push it more. also i hate gaming at low fps
drop the levels of anti aliasing down. Enjoy the frames.
i don't have antialiasing on, i don't use it on any games.
also i don't use v-sync because i don't get screen tearing on my monitor
you don't get screen tearing if your frames are lower than the refresh rate on your monitor. The point of v-sync is to limit your frames to the refresh rate of the monitor so that it doesn't try to display 2 or 3 frames at the same time aka tearing. Are you running hybrid crossfire between your APU and GPU?
no crossfire
have you tried the hybrid crossfire?
how in gods name do i do that?
honestly don't know because I don't have an AMD system. But I heard about the A10 APUs being capable of crossfiring with AMD graphics cards. I suggest a google. But I also know that if the graphics card is much more powerful than the APU then it actually doesn't help much.
