What does wattage means on speaker systems?
Some folks think that wattage is loudness, but that is not right.
Loudness is Signal-To-Noise ratio and measurement for it is dB(decibel).
Sound quality is Frequency response and measurement for it is Hz(Hertz).
How ever. As I now wattage W is Power in electricity.
My question is how does power in electricity improves sound? For example there is two speakers witch are the same only difference is Power and Price.
http://www.edifier-international.com/products/edifier-multimedia/s730
http://www.edifier-international.com/products/edifier-multimedia/s530-s530d
this depends much more on the quality and fidelity of your drivers rather than how much power you can put through them. As you push more power through your drivers they get louder but also with some distortion and this distortion rate gererally increases the louder you make it, (not the best technical explination).
Personally i would listen to these in real life to see how they sound with you favourite music etc at variing sound levels. this should be far and large your deciding factor in choosing a sound system.
Wow i see these things come in at $500. with that sort of money on the table i would rather go to a music shop and get a pair of professional recording studio monitors, i have a pair of powered studio monitors and i will never use anything else again. you can also expand to the the 10 or 12inch studio sub. to be honest the studio kit is some of the best bang for your buck. again make sure they demo them for you
check something like this out
http://www.amazon.com/KRK-RP6G2-Powered-Monitor-Speaker/dp/B001A6IC7Q
they are amazing at any sound level
my 2c
Here is some interesting article about numbers and measurements.
http://www.soundandsong.com/Issue004/004_PowerAmpRatings.html
To answer your question directly, it doesn't. Wattage is simply a measure of how much power is going through the speakers, and doesn't directly relate to sound quality. Let me go into a little more detail:
You see, a speaker may have a frequency rating of 20hz-20khz, but that only tell you a range, not what it is going to sound like at any given frequency. For example, a speaker may be rated at 50hz-20khz, however it may not actually start putting out any volume until 200hz, and may start cutting sound off at 15khz. Also, speaker curves are not linear, they have tons of weak spots. For example, when you measure a speaker output, it does NOT look like this like advertising may lead you to believe:
It looks more like this:
Now I know the first graph isn't of a speaker graph, but it is simply an illustration that the specs you see on the box mean next to nothing. In fact, many of those ratings are only at one given frequency, not the rest. Also, how much distortion should you expect throughout the range? Most manufactures will only give one rating at 1-2 volumes at 1-2 frequencies. A good example are the Infinity Primus P363's that I have. The specs Infinity puts out are:
Frequency Response 38Hz - 20kHz
Nominal Impedance 8 ohms
Sensitivity (2.83V @1m) 93 dB
However, after someone actually tested them, they rate more like a 4ohm speaker (with it ranging from 4-18), with a serious dropp-off on anything below 80hz, and more like 90dB on sensitivity (again at 2.83V, which is deceiving in of itself, as most tend to rate at 1V, giving them a real sensitivity of like 87dB at 4ohms).
So really my detailed answer is that there is a LOT of technology that goes into speakers, and simply going by specs listed is one of the biggest mistakes people make when purchasing audio equipment. Not just because the specs don't tell the whole story, but that a lot of times they are simply not 100% true.
This is why the age-old advice when buying audio gear has been, and always will be to try before you buy (and trying them out properly is another discussion in-of-itself), or if you are buying blind, to do your research and find a reviewer your trust, take their word for it, and buy them from someone with a good return/exchange policy.
OK that's a lot of information you give me. Thanks for that.
Maybe someone can tell me how are these speakers: http://www.corsair.com/pc-computer-audio/pc-computer-speakers/gaming-audio-series-sp2500-high-power-2-1-pc-speaker-system.html .
note: for a speaker to be twice as loud it needs to have 10 times the wattage e.g. 10 watts is half the volume of 100 watts. also speakers are often rated at peak power e.g. a stereo may be rated at 2.8 kw @ 120 volts = 23.333 amps , but this many times greater than the RMS power ( Root Mean Square) which is a more accurate gauge of power ( most AC appliances are rated this way).
P.S your speakers are rated RMS
"Loudness is Signal-To-Noise ratio and measurement for it is dB(decibel)."
Loudness is subjective evalution of, well, how loud something sounds. It doesn't really have anything to do with signal to noise ratio, other than that SNR is usually expressed in a common (10-base) logarithmic scale, and so dB are used as they are for sound pressure level - With the important distinction that dB (SPL) has a reference point of 20 uPa and measures sound pressure where as SNR doesn't have a reference point or a unit since it expresses a ratio.
"My question is how does power in electricity improves sound? For example there is two speakers witch are the same only difference is Power and Price. "
Looking at the pictures, those two systems aren't the same since one looks to have passive radiator on it's subwoofer and the other one has a reflex port.
Anyways, when it comes to amplifiers, power ratings aren't usually that big of a deal, unless you're using very inefficient speakers or they are a load that is particularly demanding on the amplifier (I'll spare you from impedance and phase angles here). There is some risk that an under powered amplifier could break your speakers tweeters, but you'd have to be quite deaf to ever run your sound system at such distortion.
In speakers, power ratings are even less important. In terms of speakers it means the power that the speaker can handle, and the number that is usually quoted is the thermal power rating, which signifies point where the voice coil overheats to cause a failure. What is usually not quoted, is the mechanical power rating, where failure happens due to the mechanical structure of the driver (spider that keeps voice coil in place, the cone or its surrounds, or voice coil popping out of it's gap) failing. This is usually far, far lower than the thermal power rating, rendering thermal power ratings useless. Even before the mechanical power rating is exceeded, the driver would be working outside it's linear excursion (xmax) producing plenty of distortion.
Your view of SNR is mistaken. A speakers loudness is measured in SPL like the above poster mentioned and is usually done at 1watt from 1 meter. A speakers wattage only means it can handle more power before the coil melts. Samuli knows what's up.
SNR is more so a rating on amp that let's you know how much of the signal will be desired music and how much will be static vs. a power to volume ratio.
