What do you think of my build? *HELP*
Need to ask a few questions about this setup. I already have a case, PSU, and a monitor. This is the build.
http://ca.pcpartpicker.com/p/2pw2l
Questions:
Do I need a soundcard?
I have an old NVIDIA Compaq case, will the MOBO fit?
Is a 470W PSU good enough for this system?
Is the ASUS version of the GPU good?
If I went with a cheaper, micro-ATX MOBO is it compatible with all of the other parts? is it just dependent of my case?
At the moment I have $250 flat from Christmas (I'm 14) and what part would be best to get first? I'd like to get a good deal on Boxing Day (Canadian)
And lastly, does everything seem right? Any suggestions? this may seem stupid but im young and am doing my first build and would appreciate some expert advice!
Thanks!
Your motherboard may fit, depending if you have the standoff holes. 470W is good, I have the Gigabyte 270X so I naturally prefer it but from my experiences with Asus versions they're good too :) Best thing to get is everything but the GPU first, as you can have a system up and running till' you get your GPU (what I did.)
Thanks! Ill post a pic of my case in a sec and then maybe you can help better. I think the Gigabyte is cheaper so I might as well go with that. This is a very tiny budget PC. after i buy whatever i need with my $250 i may get $300-$400 more if im lucky.
So far it looks like maybe one or two holes in the mobo wouldn't fit, is that ok?
What do you mean won't fit?
Also I would go for a Caviar Blue over the Green.
I think it may be a bit more expensive but if I can afford it then i will. Some of the screw holes on my case don't match where they should be on the MOBO. I have pics but I need a website to post it on so i can post a link on here. Any suggestions?
Use imgur.
http://imgur.com/a/VLdIl#7
If it doesn't fit for an extra $10 i can go with http://www.tigerdirect.ca/applications/searchtools/item-Details.asp?EdpNo=1963472&sku=M452-6253
