if it can play at least battlefield 2 and get me to amateur porn thats about all i really need
NW8000 is the machine for you.
I don't want a new computer that's limited to to 'Old' I/O and features. I chose my current motherboard as it had M.2 and USB Type C. Maybe my next computer can get 10Gbit ethernet. (I wish).
Also Linux support is a must for me.
what do i need in a pc?
Needs to be a laptop. I travel around too much for it to be a pc
720p screen. anything lower does not have a high enough dpi for me. i run firefox at ~75% zoom @1080p
4gb of ram but could maybe get away with 3gb
some form of linux with dnf package manager
some form of wifi since nobody has ethernet anymore
12" - 17" - nothing less and nothing more
dual core with HT at 3+ GHZ
a grapics card with 1gb of vram that can run titles upto 2010
2 usb ports
500gb HDD
headphone port
What do I need in a PC?
flexibility
Most days I am doing Photoshop, but some days I may be doing 3D solid modeling for finite element analysis of an engineering structure. Who knows what zany experiment I may think up next?
Fortunately because I want to play AAA games in high resolution and at high framerates, a PC built for that is flexible enough to handle nearly anything.
When I was helping my niece pick a computer for college she wanted a netbook "I only need to do word processing." I said "A netbook may serve your needs now but after a few years at school... Who knows? Your needs may change. This is not a time to cheap out." She bought an i5 Dell laptop, because it was pink.
My 7850K fulfilled all my needs. Luckily for Microcenter shareholders I really wanted an 8 core, 770GTX build:)
Portability - The one thing I don't have right now.
Considering I used to do CAD work with an 11.6" AMD E-450 laptop, I don't need that much power.
For me it's being portable with at least 8GBs of RAM. I will use a lot of RAM having multiple applications running while I listen to music. Lot's of screen real estate. Other then that I don't need much. Most of the games I play are Dwarf Fortress and SimCity 4.
I've talked about what I want in a desktop, lemme talk about what i want in a laptop.
I have different criteria for laptops depending on what it is I expect them to be able to handle. But here are some of the criteria that ALL my laptops must meet regardless of their use case, or I point-blank refuse to use them.
- they MUST have an SSD.
- they MUST have a user-serviceable battery (i.e. one that detaches from the back)
- they MUST have an easily-accessible motherboard, either by detaching the keyboard (older thinkpads) or by a removable chassis plate (MSI, etc)
- they must be of at least reasonable build quality - laptops should be tough and flexible, not flimsy. This takes the vast majority of consumer laptops off my approval list.
- They must have decent cooling properties. If the laptop in question has a dGPU, it must do a good job of cooling regardless of the noise, even at idle. If it does not have a dGPU, I expect it to be near-dead-silent at idle.
- not a requirement, but given that my options are never limited to brand new laptops, I like my laptops small, 14" or smaller. Lugging around a 15.6" laptop regardless of how thin it is kind of defeats the purpose of a laptop for me.
If I'm traveling and I see myself wanting to spend some time gaming, a small workhorse with a good power to weight ratio is what I need. QC i7, GTX 760M or better and 8-16GB of RAM and I'm happy.
if I just need a decent laptop for taking notes or drawing, a used business-grade laptop is my go-to option. Sandy Bridge i3 or better, 8GB of RAM. ExpressCard slots and Wacom panels are nice too. The touchscreen on my X220T is great. It has a Wacom digitizer too, so I can use this as a $160 Cintiq killer.
if I'm getting a Linux laptop, the bar is set much lower. 3GB of RAM and a Core 2 Duo T7700 is a good start. Like the general-purpose Windows laptop, I like these to be older Thinkpads or Dell Latitudes because they have thick magnesium frames and resilient bodies. Drop them off a table, leave them out in the rain or put them between two 15kW Tesla coils and not much will happen.
Other things I try to look for:
Displays - something that isn't 1366x768. 1366x768 is the satan resolution, but I can forgive it if it is an IPS display and small enough. Some T61ps have 1920x1200 TN panels which are... really, really nice for their age...
I also try to look for laptops that have large aftermarket parts surpluses. Business-grade laptops that are or were manufactured and sold to businesses by the thousands have tons of OEMs selling cheap replacement batteries, hard drive sleds, etc.
What do I need in a pc? It depends. Is it my work PC or is it for leisure?
Let's start with work:
- something that can compile with decent efficiency. I spend a lot of time optimizing kernels for my company's openstack implementation. (I suppose I could distcc it if need be)
- good network connectivity. (I'm talking 100mbps)
- somewhere around 500GB disk space. Don't care if it's SSD or HDD, Linux is fast enough for either to get it done.
- 1920x1200. Based 4:3 is the only option.
- mechanical keyboard. Fingers get tired with membrane keyboards.
Now, on to leisure, this is harder to figure out. Do I specify need as a want or do I specify it as the bare minimum, because if that's the case, I could probably get away with the specs in OP. That said, I do enjoy playing some AAA titles on occasion, so I would sorely miss my 6700k and Fury if I were to ever give them up.
I think defining need is a matter of determining quality of life. If you're near broke, you don't need a car or a house, an apartment near a bus stop will work fine, and will be less expensive. That said, you may need the car to maintain a certain quality of life. I'm saying this because I have a certain quality of life that I'm trying to maintain and I'm only going to be able to do so with certain things. I like to sit down in front of my expensive color-change machine and make the pixels dance. That makes me happy, but it's not something that I need to survive.
Currently, I would argue that I need:
- i7 (could probably do with a 2600k at 3.8GHz or 4GHz)
- 8GB ram (at least 1866mhz)
- recent gen mid-tier GPU
- accurate mouse and mechanical keyboard. (preferably cherry browns)
What do I need? I need for companies to update drivers for old hardware that is fucking amazing so I don't have to use a windows version that's older than I am. Fuck you windows 3.1. Fuck you 32 bit. I can't wait for 128 bit os. Moar vectors.
What do I need? Depends on if we are talking 100% minimum for me to be ok with my PC and an ideal
First lets do the Ideal:
I already own a 40inch 4K, so I need a PC able to push 4k gaming to at least medium settings I think that translates to roughly this
i5(or Zen) would be fine
likely a 1060gb or 970 or RX480
8gb-16 of RAM
a decent SSD
A minimum build ignoring my 4k screen
still an i5(or Zen), maybe a lower version
a 1050 or 470 would be fine for medium 1080
6-8gb of ram still
An SSD would be a nice to have, but not needed for a minimum
Now what do I own?
i7 4790
980Ti
16GB RAM
3 SSDs and a 2TB HDD, with 2 3TB HDDs as a crappy backup
Dances with pixels is my favorite spoof film
Well in terms of what do i need for my usage? It would be a laptop with a decent CPU maybe a quad core i5 and a nice gpu to play some games with friends or when i'm not in home. It would be my perfect daily driver for school and some gaming.
On a desktop have a decent setup to also game when i'm in home, maybe an i5/Ryzen equivalent would be the max i would need, and a rx 480 for 1080p or maybeee a gtx 1070 for 1440p gaming and must be silent.
I dream to have a workstation/1440p gaming setup when i finish university and start working on my engineering field. But i think a quad core its enough for me
This should be a thing.
Actually, this is a thing.
A Chromebook is all I need. I don't really do PC gaming.
Sometimes I can't tell the difference between dancing and randomly flailing around.
This is one of those times.
That's Okay.
It is perfectly acceptable to not know how to feel or to feel uncomfortable when ART takes you outside of one's comfort zone. At first I thought it was pretentious and weird, but I watched the whole video and liked it.
Thanks @SgtAwesomesauce !
Very true. This was the first thing I noticed when I searched for Dances with Pixels. It's definitely a cool idea, one way or another.
