What do you guys think of my build so far?
http://uk.pcpartpicker.com/user/rebornash/saved/2Wuz
So here's my gaming / editing build that I'm planning on building early February of 2014 (yes it may seem early but I've been saving since March) I'm aiming for around a £1200 - £1300 build so this is at the top range of my budget however it does have windows included.
My key focus for the build was to be as quiet as possible after having a very "ok" HP laptop for over a year. And while it can do some of the things I need it is slow and very loud. The price of the build fluctuates a lot so I look at it daily and may make small changes over time. This system is built for
  • High end gaming
  • Light editing
  • Silent + Performance
  • Overclocking
  • Looking great (even though there is no side window due to keeping it quiet)
  • Playing games at either 1440p or 3x 1080p
  • Streaming
If there's one thing I'm not too sure about it's the CPU cooler. It will fit with the RAM but is very close and I'm wondering if it's just a bit over kill. However don't recommend water coolers it's just a personal preference but I'm not a fan. I'm wondering if the GPU is a bit too much and would probably go for the 290 however with it's current noise problems that's out of the options. So what do you guys think and how could I maybe cut some money off this build ?
If I recall correctly, the Noctua NH-D14 should come with a thermal paste.
Ah ok , I wasn't sure so I put a spare in there. I'll look it up and probably remove it. thanks :)
