What do I need to update right now!
Hey Guys I just need some help on what I need to upgrade right now so I will be good for the next couple years!!
I Have
AMD fx 4100 BE
Asus m5a78l-m lx plus
msi gtx 660 twin frozer 3
Mega Power 550w 80+ power supply
WD 1tb green
Samsung 830 128gb
Kingston Value 1333mhz cl9 2x 4gb (8gb)
Cooler Master Hyper 212 evo
i was thinking a fx 6300 and the mobo the logan recomended with the fx 6300 on his mid level build guide
psu-get a more reliable brand.
cpu- upgrade to the fx-6300. your mobo is fine
Sounds good. The only reason i was looking to update the mobo aswell is because its only a sata 2 board and you carnt overclock with it. what do u think. do i need the overclock and the sata 3
If you can afford it get the new mobo with the 6300 because that would be alot faster once overclocked and you will have a really good setup :)
what are you looking to spend? min-max
im looking at the 230ish max range
but would love to spend as less as i could lol. if i was spending over 150 I would like a mobo aswell
The advantage that I have is that my girl friend is america so I get her so ship me parts and I live in New Zealand so I can sell my parts for way more then they are worth. for example i might get 170 ish for my mobo and cpu in over hear.
http://ncix.ca/products/?sku=76522&vpn=M5A97%20R2%2E0&manufacture=ASUS&promoid=1360
http://ncix.ca/products/?sku=76934&vpn=FD6300WMHKBOX&manufacture=AMD&promoid=1270
THESE ARE THE TWO I WENT WITH AND VERY HAPPY WITH THEM auto tune overclock set in os at 4.2mhz they really work well together.
Thank you :) Thats the advice i was looking for :)
