So I basically want to get these speakers* and plug them into this amp* and then into my record player. My record player has an aux output and I have an adapter to plug it into the amp, but past there I don't know what to do. I don't understand what cables I need to run from the amp to the speakers, help would be appreciated (I know im an idiot XD)
Your record player should have RCA out. If it only has a single yellow rca jack, then it is a mono record player and then you have many more problems than I can even begin to help with.
The rca should go directly into the amp.
From there you need speaker wire. Ideally you should use banana plugs at the end of the speaker wire, but if you simply ball up the ends of the wire and shove them in the hole, it should work just as well.
