I have 4 RAM sticks
Spin the CPU heat sink 180 degrees?.. so the tubes are on the other side.
I think then the rgb logo is gonna be upside down.
Do you want the logo you will not look at 99.999999999% of the time to be the correct side up or do you want to have all the ram you paid for to be available 100% of the time…
Also I’m too lazy to clean and apply the thermal paste again. I will probably do it anyway.
It’s like ten minutes.
#worthit
