ok i put mint on my usb installed in windows went to reboot got this: Try(hd0.0): ntfs5: no wubildr
help
help
Did you change your BIOS settings to boot from your USB?
yes
http://ubuntuforums.org/showthread.php?t=1639198
ok what am i suppose to look at?
the program i used to put the os on the usb stick doesnt support the verison im putting on the stick i dont know if that is causing the issue
