I want to cool both my i5 2500k and Diamond Radeon 7870 for about $175ish
For that prive I am not aware of anything that will be able to cool both that GPU and CPU.
email me at [email protected]
*price not prive...
unpossibru. you could cool your cpu for that price, but a gpu waterblock will be pricey
For that much? Your best bet is probably to buy two Corsair H80i and a bracket for your GPU from dwood from OCN.
Otherwise just the waterblock for your video card will run you over $100.
Then what about for just a CPU
actually if I could push my budget to $240 could I get a custom loop for the GPU and CPU?
Your gonna need to bump that to about at least $400 before you can even think of having that kind loop. A decent cpu and gpu block alone will run you near $175-$200 and then you have the pump, res, rad, fittings, tubings to worry about.
^ what he said.
$240 will get you the blocks, lol.
