what cpu should i get FX 8350 or intel I5 4670k?
8350
8350 no doubt :)
8350
8350
You havent given enough info to answer without personal bias
my comment got refreshed and I lost my paragraph, give me a minute
Check out these links, 8350
https://teksyndicate.com/forum/cpu/8350-vs-4670k-future-gaming/163083
http://linustechtips.com/main/topic/49318-should-i-get-the-i5-4670k-or-a-fx-8350/
http://www.anandtech.com/bench/product/697?vs=837
they trade blows, but the 8350 can be overclocked to be faster and the money saved can be put towards a better cpu cooler
If you don't plan on overclocking, get an 8320, overclock it to 4.0ghz and put the money saved toward a 990fx mobo instead of a 970, or a tier higher gpu, or a cpu cooler, the money saved getting an overclocked 8320 @4ghz(really a cheaper 8350) is a large amount.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285 $160 8320
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284 $200 8350
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899 $240 i5 4670k
$80 cheaper for the same, if not slightly better performance. Its up to you, but $80 is a lot to put in other parts of a build.
Hope I helped
Thanks man. That really help me out a lot.
No problem, happy to help
