Just downsized to micro atx. Im now running a node 804 case which I love..however my beloved thermalright true spirit 140mm wont fit the case. So im now looking for alternatives. Im more inclined to go with air but am open to suggestions to other alternatives. Im running a rog vi gene too so not sure what clearance I have with that.
I was getting 4.5 overclock on my 4670k on my thermalrights too.
I have the same case and same mother board. Is the issue that the side panel is to close or the ram gets in the way? If i was you i would go for a AIO water cooling unit. The node 804 gives you heaps of mounting options.
The thermalrights were too tall..side panel wouldn't fit. I was looking at the seidon 120v but not sure if it will fit the back exhaust..ie too long and encroach into the expansion slots below...
