what differences are there between two, lets say 8320s.
is it only how much they can achieve with a set voltage? like: one gets 4.8 with 1.45 and the other gets up to 5.0ghz.
or does other stuff also change? like the temperature on the same settings? for example: both at 1.45 and 4.7ghz, one runs at 50°C the other 55°C?
i was wondering that because my FX-8320 was running very hot (63°C @ 4.7ghz - 1464mV) on a custom cooling loop (240rad with 2 NF-F12 and 120rad with 1 NF-F12, Ek-supremicy block) while others were running higher voltages on mid-high end closed loop coolers and only got to around 55-58°C.
Chip variances happen when constructing at nanometer levels that create different performances for even those chips binned to the same category and clock speed.These imperfections in a chip cause voltage leakage to other gates and NAND arrays, which can create instability, errors, and higher temperatures even at stock clock speeds and voltage.
One example of this happening on stock setups would be the R9 290/x. It's clocked so high that there isn't much wiggle room for overclocking, and some chips run so much hotter at stock levels that the fan couldn't cool it fast enough at the rate it was spinning at and caused clock speeds to drop to stop itself from going higher than 95C. AMD had to adjust the fan to run by RPMs instead of a percentage because of this in order to maintain finer control over cooling. Most of the review units shipped to reviewers were very good, though the ones on the shelf varied pretty significantly in performance and temps.
So, in the end, overclocking shows these imperfections as heat and instability.
my cpu is actually really good except for core07. i could run it at 4.7ghz with 1.45v without it, but with it enabled i need at least 1.48v wich is running to hot for me.
but i dont think it would be worth disabling 2 cores for 200mhz more.
Basically all answered by st33med and enko. The "Silicon Lottery" as it is called, meaning one CPU and another will never always be the same.
Another good example is I owned two Phenom II x6 1605T CPUs. One of them I was able to push to 6.1GHz on all cores, then the other would never reach past 4.4 with the same settings.
