im planning on doing a build with the kraken x60 but im not sure what case. i like the phantom 410 and the corsair c70 but will it fit???if you guys could suggest others the only thing i request they have is a window and rubber gromits and under $120 please. thanks in advance!!!!
Depends on the size you wish for your case. Given your primary choices I assume you don't desire a very big case. If so, I wholeheartedly recommend the Fractal Design R4. It is extremely quiet while still having excelent cooling and a small form factor. IF you can swing 20 more bucks pick up a CM Storm Trooper if you are comfortable with the size (I have one myself. Lots of room, easy cleaning, lots of fan mounts and support for XL ATX boards if required.)
