What can I get to improve on my build..?
My specs are:
Motherboard: ASRock N68-GS3 UCC
OS:Windows 7 Home Premium 64bit
Processor:AMD Phenom II X4 850 Quad Core AM3 3.3GHz x 4
RAM:8GB DDR3 RAM
1TB Hard Drive
Graphics card:ASUS EAH6850 DirectCU 1GB GDDR5
I feel as my computer lacks the power I intend it to have as it takes a lot of time to tab in and out of games and takes a very long time to load into Team Fortress and many other games :(
Please help me on what I can get to improve the performance of my build.
SSD or going intel or both
an ssd will fix the load times into games
any specific ssd?
yep SSD, Overclocking your CPU if you haven't already too, if you don't have a CPU cooler I'd advise a Coolermaster hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226236
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226226
also defragment you HDD with defraggler
Any UK sites?
http://www.overclockers.co.uk
http://www.scan.co.uk/
I'll find a specific one when I get off work, gotta go
120GB
240GB
http://www.anandtech.com/bench/Product/400?vs=637
Thank you!!
