Im trying to get a most bang for my buck here while staying around the budget of $1,300 if not less. What would you guys suggest i change, swap, remove. And yes i need an i7. currently using a AMD 8350 and find myself using 6+ cores often.
I thank you in advance.Well, depends on what you're doing.
1. Cheaper mid tower case.
2. Hyper 212 Plus performs 1-2c less than the EVO, but it's usually 5-10$ cheaper depending on where you get it.
3. A decent 550w psu should power that just fine. 750w would be ideal if you plan on getting dual GPUs
Fancy build :3
Not trying to be troll but if your currently running an 8350 why switch to an i7. can't you upgrade your current rig to achieve what this system does.
Ah, yes I can. but see i put $850 dollars into my current 8350 build. I have a possible buyer that will buy it off me for $1,200. Basically I'm upgrading from a GTX 660 to a GTX 780 for about a hundred bucks.
