I currently im using BitMinter. Im shur there is currently better, what do you use?
I use cgminer.
well how exactly dose it work?
cgminer is probablt he most efficient (gets you the highest hashrate). But it takes quite a bit of setting up and troubleshooting can be a bit tricky.
Otherwise, guiMiner is pretty good. Its simple, easy to use and troubleshooting is pretty easy.
