Hi! I need a lightweight remote desktop solution that’s simple to set up and won’t put much strain on the system. It’s mainly for occasional support of a few remote users, not for full-time remote work or big deployments.
Best Korea fishing (j/k)
Teamviewer, AnyDesk, Rustdesk.
xrdp
Teams screen share with mouse control is how we deal with most remote support.
Depends… what is your host system? And what are your target systems?
If Windows, if you have a Professional/Enterprise license, and your users are on the same network, then RDP is a great option.
If both use Windows, but not on the same network, then AnyDesk or TeamViewer are easy options.
With Linux, I’d go with XRDP if you can get everyone on the same network. Remmina works great for that in my experience.
Otherwise I’d go for AnyDesk or TeamViewer for easy options.
Or Rustdesk as an AnyDesk/TeamViewer alternative if you have the option to host your own server for it.
I’m currently using HelpWire. It’s free, easy to set up, and has reliable connections.
From what I’ve tried, I’d also recommend AnyDesk and TeamViewer. Both are fast and simple to use, though their free versions have limitations.
