i want to know what the best free antivirus software i should be using becuase im a little worried about my security. i currently use ad aware antivirus (free) and the one that comes with windows 7. i want full protection with keyloggers, antivirus,malware i need a program that does all that so what do you guys recommend to me
I've really liked Avast but recently I've been stumbling into some problems with them regarding problems in recent updates.
I'd reccommend Microsoft Security Essentials, it actually is quite good.
AVG Free an addtion to MSE, both do a pretty good job, haven't had a virus in years.
Also get adblock and noscript addons for Firefox or Chrome if you have either.
I'm using AVG Free in combination with Spybot: Seach and Destroy. I've heard AVG isn't that great, but it seems to get the job done well enough, and Spybot is a pro at detecting different forms of spyware and getting rid of them.
I use Avira Antivir which is free for personal use. It has a good reputation and it's lightweight on your system. My only problem with it is the pop up ad that comes up after every update but that's because it's free.
I stopped using AVG when it just wouldnt stop freaking removing files I knew were safe without noticing me.
Have used Microsoft Security Essentials for a long while now. Loving it. It does the job, without eating too much resources and it never bothers me with anything.
Lol, I guess it's time to switch to MSE then.
I use AVAST, no problems so far. I disable MSE because there are things I do that MSE inhibit and they like to keep a nice record of all the things I do and I don't like that. So I just use AVAST for AV.
i used milwarebites for windows..now i unse none cus i use linux ^^
I can't seem to find one that is better than PC Cillin... It's not free though.
I use avast. Works damn good!
Norton 360 Premiere, it never asks me to do anything and keeps my pc in shape. Just look for a deal on Frys.
I use BitDefender 2013 Ultimate, there is a 30 day trial and it works well but it costs, try a combo i used to use, i used to use AVG Anti-virus free Malware Bytes and Spybot for the big scan times, also learn to use SmitFraudFix incase you come into contact with a big virus chances are SmitFraudFix can remove it, if not Malware Bytes probs will :)
i dont use an AV.... common sense is the best AV and if you know the registry like i do, you can find were most viruses hide... but i always recommend avast to customers. best free one out there imo.
thanks i will try these and see what ones i like
Hey guys you should try Comodo Internet Security it is completely free and believe me once you try it you won't change, now I've been holding to CIS like for 2 years and 2 more PC at home have been working with CIS too and I've never had any type of issue in all this time. It's also very light so you will certainly feel your pc running faster. www.comodo.com Comment on what you think once you try it :D
