What 7970?
I'm plaining to get the 7970 but what brand I want to overclock but with so many out there I don't know I'll be getting sabertooth 990 fx R2 and 1000W power supply and the nzxt full phantom thank you
asus, sapphire, msi, xfx are all good brands. asus in particular has excellent cooling. make sure that the one you get uses a non-reference model cooler.
well I was thinking of www.amazon.com/DirectCU-Edition-1201MHz-Graphics-GTX680-DC2T-2GD5/dp/B00814JQPC/ref=sr_1_6?ie=UTF8&qid=1363055079&sr=8-6&keywords=asus+7970
it's a 1200mhz gpu it's $572 whitch is insane but then again
ummm... that's an nvidia gtx 680.... not a 7970
if your going to spend over $500 on a gpu, make sure it's what you are looking for.
http://www.amazon.com/ASUS-DirectCU-28nm-Graphics-HD7970-DC2-3GD5/dp/B007B5P9SU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1363055834&sr=1-1&keywords=asus+7970
that is the asus 7970
sorry been a long day lol
what brand would you recommend? I need somthing like oc well 400 450 ish mamby 500ish
Xfx is great and has a lifetime warrenty and better parts than other brads. Plus it has a dust free fan system so you card will last a lot longer. I think Asus and xfx are really the only ones you should be considering. Just my opinion though
