What 7970 should i get?
i have posted this before but didnt really get anything out of it, so what brand amd radeon 7970 should i get? i want to get a 3gb card, but i dont really know much, so any help would be great. if you give me a suggestion tell me why i should go with that brand. thanks for the help.
A: A gold one with spinning rims!!!!
B: tell us your budget, water cooling or air?
 You got the following 3 in the same price range.
HIS HD 7970 IceQ X² GHz Edition
MSI HD 7970 Lightning BOOSTED
Asus HD 7970 Matrix Platinum
All 3 are good buys, but comes down to case size and cooling.......if you got the room and want to OC, I'd go with the 3 slot behemoth Asus HD 7970 Matrix Platinum. Or if you REALLY need the RAM for multi monitor action, you got the Sapphire HD 7970 VAPOR-X GHZ 6144MB is about £100 more!
The MSI 7950 is a good deal at the moment
