What 2011 mobo for i7 4930k?
I am looking for a motherboard recommendation for a i7 4930k.
I'd like to stick with an Asus motherboard,
I am not sure of which one to go with.
I am between the X79 Deluxe and the Sabertooth X79
Are there any other good 2011 socket alternatives?
Is Asus making new 2011 motherboards this month?
Planning on using 16gb (4x4GB) or 32GB(4x8GB) to use the quad channel capabilities from the x79 chipset.
Both of those motherboards would be fine.
Both of those boards are good, the Deluxe is a newer board so it has some of the newer features. But the Sabertooth is a part of the sabertooth line. See which motherboard has the features you want or need and what features you can live without and choose the one you think is best
Yes both board are great, its abit depending on the feutures you prefer, but basicly both boards are realy nice. the Deluxe is indeed a newer board, and will have some more feutures to offer. But both boards are awesome.
Offcourse if you just want the best board then the Asus rampage IV Black, i just the top of the line. ☺
