Wendell: Vertical Tabs and what else?
In the last episode Wendell mentioned vertical tabs and other extensions for FF he uses. What are those other extensions? Also, Wendel, do you have taskbar on the side?
I was demonstrating TreeStyle Tabs and Tab Wheel Scroll to everyone for years but nobody installed those. That brings me to the question for Logan: how come Wendell could not convince you to use those?
On the topic of vertical tabs... If someone else also agrees that this is #1 productivity extension, and you are early adopter, having Windows 10 Technical Preview installed, may I suggest searching it on their Feedback Tool and clicking Mee Too on that one for Internet Explorer. You may never use Explorer, but if IE was also on board, maybe Chrome would bring it back again (it was supported 20+ versions ago and is the main reason I do no use chrome).
Thanks!
PS; Some places on FAQ and descriptions it is written Wendel and some Wendell
