@Wendell - Hard drive corrupt/unreadable
@wendell My hard drive won't work, when I plug it in it says corrupt and unreadable.
What can I do to fix this?
https://gyazo.com/3c950bff018d3ada2288022c23295c12
https://gyazo.com/9f0eb1e153d186e41da85141fe21b216
try the program like
UNERASER
Linux live CD? Might be the safest way to proceed. To avoid making it worse.
What would I use the live cd for?
Boot from the live CD and see if you cAn read only mount the file system and copy what you need.
I will try that and reply with the results. Thanks
4 posts were split to a new topic: Corrupt partition, file recovery help
