my next build will have a 4870X2....should i get a GTX295 instead?(X58 mobo)
gtx295 is the newer card and has marginally better performance. it's all in how much you're willing to spend.
KOkun wrote 1 hour ago ยป
If you are willing to spend that much money the 295 are better but that is going to cost u a pretty penny
I would recommend a GTX280/285, it's a really powerful single gpu meaning that you won't have to do deal with multi-gpu scaling. Plus you processor will probably bottleneck the crap out of a GTX295.
A core i7 would not bottleneck a gtx295. lol.
hahahh ultra u failed
technically it would bottleneck a GTX295, But you wouldn't care. I'm just saying that a GTX280 is better, great single GPU performance and if you want you can just add a second one later on.
It would not.
If you believe it would so thoroughly though I would like some proof sir.
I read somewhere that to not bottleneck a GTX295 you need to oc an i7 965 to kill bottleneck. The performance would still be good, but technically there would be a bottleneck, you wouldn't care though.
links or it did not happen.
Bitches don't know about my Teslas
Bitches know bout my Lubriderm.
Ownnnnnd
