First of all if I was you I would save some money and buy fx system straight away - you see athlon is very old now and I do not want to sound rude but in my opinion it's just like throwing money away, because with FM socket you'll be able to upgrade to APU (For FX you'll need to buy new motherboard)
As for openbox - if part is not damaged (read description) then it's okay - I've got a bargain with those, because I've got the only one processor that was on sale in my whole country because of that (Manager said they didn't had 1045T in stock, but had openbox 1055T that wasn't on sale and I could get that for almost same price - funny part that when I was in checkout they showed me real price that was three times bigger).
As for FX series - they are more advanced than Athlon and FX is much more worth to buy
Case is good for overclock as long as it is supporting efficient amount of cool air from outside and exhaust all hot air from inside - so consider it to be with good cooling solutions
ok just hold up. Did you just say that case is good for overclocks when he doesn't even have a aftermarket cpu cooler? Also fx vs Athlon. The Athlon is not throwing money away. I would be scared to even run a 6300 on that old ass motherboard, so either way, he's going to need a new motherboard when he upgrades. Also you can't run a new Apu on that motherboard. You need to get a A88x motherboard and then flash the bios to use one currently. You can use the A10-6800k, but none of the new parts. And the Athlon is already faster than the A10-6800k so why would you? It's not like he's going to use the integrated graphics when he already has a graphics card.
you can't run the FX 6300 on a micro ATX mobo... insufficient power delivery... hold up and I'll try to build something around 600 around the FX 6300...
you can pleasantly overclock on that board but you REALLY need to have a CPU cooler... not really an option with AMD builds... the provided cooler makes for an unsubstantial coaster... and if you want to overclock it's not just a must... it's unsustainable period without an aftermarket cooler...
I do understand you're on a budget but I don't think you realize the difference between a 2GB R9 270, 2GB 7870 GHz, and a 1GB 7790... it's a large step up and well worth the price of the step up...
Windows gives you 30 days to activate if you want to buy a legit copy... (it's also very easy to get for free) and the optical drive is really not necessary unless you want to burn CDs... you can install Windows from a USB...
That being said.... that build looks LOADS better than your last one
If you're on a budget, I honestly think you should get an athlon. Its not as sexy as a fx cpu, but pair a 760k with a 7870 and that machine will preform quite well for the price I would not recommend a 7790 unless you plan to upgrade in the very near future Add to the fact that you seem to need windows I can't justify the cost of an fx 6300 for your price point when an athlon will get you very decent performance. Can you salvage a hard drive from a laptop or something?
