I typically have my dpi set to 102 and everything was working fine until I installed virtualbox, I believe one of the qt dependencies it pulled down is the culprit.
After rebooting my dpi in urxvtc had shrunk to what I figured out was 96 even though everything I can think of checking (xdpyinfo, xrandr & xrdb) all reporting 102.
I removed vb and everything it brought with it but no change, urxvt (and everything else on the system I think) is working as it should but not urxvtc.
here is a side by side comparison: left=urxvtc right=urxvt
anybody have any ideas as to what is wrong or what I can try to fix it, my google-fu has failed me?
edit: I should mention in my xinitrc I have urxvtd start after I have set the display options:
userresources=$HOME/.Xresources
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
systemctl --user import-environment DISPLAY
xrandr --auto
xrandr --dpi 102
urxvtd -q -o -f
