I'm doing a desk upgrade. I have two Acer 1080 IPS screens from the local Microcenter. I want to add an ancient third monitor to the setup. I plug it in, and nothing happens. I fiddle around with the Display section of the System Settings, The third monitor is not there. I look in the AMD CCC and it is there but disabled. I try to set it to Extend. It says that I would need to disable one of the other screens. I do the same thing in the Control Panel display area. I get a similar response. Just as a sanity check I then booted in Ubuntu. Aside from the arrangement being wrong everything works. Any advice?
Relevant Specs:
CPU: AMD 8320
GPU: XFX AMD R9 280 (non-X) Dual Dissipation
RAM: 16 GB
OS: Win 10 x64 and Ubuntu Gnome 15.04 x64
Notes: I have tried with both the 15.7 and 15.8 drivers with no luck.
Acer monitors connect over HDMI (or VGA) and the old monitor connects over DVI (or VGA)
I have some HDMI cables, DVI-HDMI cables, and some Apple (don't ask) Mini-DisplayPort to DVI adapters (GPU has Mini-DP rather than full size DP).
