Before I ask I should say that I AM new to the pc building world, but I have had my machine built and running no problem for about a month now.
I started up my pc a few days ago and prior to the post beep, there was a sort of continuous beep. This is the first time since I built it that anything like this has happened. I can only assume that it's an error from the motherboard, but I don't know what it could possibly be because everything works perfectly fine otherwise.
I recently installed a 3Tb HDD (which went smoothly) and the noise started occuring after I had it installed. I thought it might be a hardware problem at first, mistaking the alarming noise for grinding, but it's definitely an electronic noise.
Aside from the 3Tb, I am running the following:
AMD FX-8350
Gigabyte FXA990 UD3
MSI GTX 660 (factory OC)
16Gb RAM
120Gb SSD
750 watt PSU
Thanks in advance for any help anybody has and if anything's not clear I will do my best to clarify. :)
