So I switched from a flaky LSI 9211-8i yesterday to a LSI 9400-8i. I had an issue with my drives dropping off with the 9211 so I figured it was the card that was having issues and would “upgrade” to a newer model. Today however I just noticed the below messages in event viewer from it. Not sure what I need to do in order to fix it, I did install the latest driver for it as well from Broadcom’s website already.
Error is below:
"Event 44802, ItSas35
The description for Event ID 44802 from source ItSas35 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\RaidPort1
SAS IO Unit Ctrl sent for TimeSync Failed (IOCStatus logged)
The message resource is present but the message was not found in the message table"
