Weird color distortion
Hi, for a while now iv'e been having weired line like color distortion through my monitor. originally i thought my monitor was dying so i replaced it, didn't work, so i thought it might be my GPU so i replaced my old 550 TI with a 770 SC ACX and there's no difference same lines. so i replaced my motherboard and cpu still nothing! the only thing i haven't replaced it my ram and iv'e tested my Finance's OCZ ram in my pc and still nothing!
pc spec if needed:
AMD FX-6300
Asus M5A78L-M
ram has no manufacturer on it but 4GB (works in Finance's pc fine)
Asus 770 SC ACX cooler
Corsair GS 800 PSU
also, if i screen share i.e Team viewer, the lines do not show. i know this because i often play Civ5 on my mobile on the way to and fourth college.
EDIT: forgot to mention some thing rather important, it only happens if im on flash, transitioning from app to app (im on win 8) and when on direct x applications. and has only just today developed a quiet whine when loading games, large programs ie photoshop or c4d.
I know this is probably something you thought of first. But I have to ask did you replace the cable running from your computer to your monitor? This sounds like a similar problem I had.
yup, when i got my new monitor it supplied me with one so i used it, my old one is in the back of my room for the day i have time to install dual monitors. if you would like any further info just ask.
no one know whats up?
Don't know your issue man, but a picture would sure help
whatever color it is (say i'm looking at the sky in a game) there will be darker lines straight across my screen. I.e
the sky is 0084ff and there are big lines all over that are 0060ba (html refrence)
http://www.colorcodehex.com/0084ff/     < what the sky should look like
http://www.colorcodehex.com/0060ba/   < lines are covering the screen
this happens with every color everywhere i just chose the sky cause its the easiest way to describe it.
sorry i didn't show a photo, i dint have a camera that can pick up color differences like that.
next step is to replace your eyes.
isn't just me that can see it. all my friends can.
do fresh OS install.
have gone through many, windows 7 , 8 and Ubuntu. i get it in all
maybe you are being monitored by the NSA
ohh yay a tinfoil hat guy :P
a glitch in the matrix?
make sure to watch at 1080P + full screen the weird light colour distortion thing is really irritating me and im kinda worried about damaging my pc when i see those lines.
http://www.youtube.com/watch?v=1G6WZrew9Hc&feature=youtu
this is what's happening. ive just replaced my mobo with a Crosshair V Formula-Z so its not my motherboard.
Have you tried to move your pc to an other place and test it again? I mean it can be caused by magnetic fields . . . are your speaker shielded? Do you have a pc speaker in your tower?  I mean you changed everything and it still happen . . . maybe you life under/near a cell phone tower and this is causing it?
Useing VGA?
No speaker in my pc, only speakers in my room are logitech ones (cant remember the model but I don't think there doing it cause ive had them way before this happened) ill try moving my pc, I understand your concept of that.
DVI - VGA adapter however ive done this "solution" for a looooong time I know I need a better monitor, I will be but first i want to fix this issue.
Get a dvi cable problem solved that shimmering you see in lines is from useing VGA its a common problem when converting analog to digital or vice versa.
uhh not problem solved. if you read the 1st part of it it only happens in Direct X games.
