I always seem to have problems connecting to this site and often just get a blank page and it can take a few goes for it to turn up. Is it just me ?
Most likely.
As this works for those of us on the E/W coast.
The site is cached by CloudFlare, if that will give you anything for further digging.
I will add that this happens in Ireland too, semi frequently. A few times a month, a refresh usually clears it but sometimes it is down for the day, never thought to try shift refresh.
I also sometimes get the blank page when loading the https://level1techs.com/ main page. (I’m in Finland.)
Chrome just loads for a while, and I get a blank page with no content (or HTML). Happens around 1/4 to 3/4 of the time, and if it happens once, chances are it takes at least a few reloads to get the actual page. Or I give up and return a few hours later.
EDIT: Shift refresh doesn’t do any better than regular refresh - at least I haven’t found it to reliably load the page.
EDIT2: Just now, I returned to the site after 30 minutes, and it took 10 tries to get the page to load.
Am in the UK and see it’s not entirely unknown
As an update to this continuing problem, I seem to have found a workaround.
When the site refuses to load:
Press reload.
Interrupt the reload (from the “X” that replaces the reload button).
Press reload again.
This has worked for me for about a month. Today I got the problem for the first time on mobile Chrome (Android), and it worked there, too.
I have that problem from time to time, I just paste the link into a new tab and it works.
Didn’t had a single problem ever, with the website or this forum. Was also very active past few days. Very strange behavior. Central Europe/Slovenia.
I second that. (western side of central europe)
Ionky used the site as a mean to take a look around at what was news and drive a few views. But happened regular enough that I have just given up and have a direct shortcut to the forums now.
The forums never had a problem loading. Just the L1T website.
I still have this issue… just wondering if this is going to be addressed.
forum.level1tech.com loads completely fine.
level1techs.com just loads a blank screen and despite numerous refresh attempts will still have trouble. Even once I’ve loaded it I can’t seem to smoothly navigate from “Videos” to “Articles” and back to the home page without some sluggishness or just another blank screen.
If anything I’ll have to copy/paste the URL into a new tab and see if it works and start the trial & error all over again.
Yes, me too. Problem persists, although it’s intermittent, and sometimes the site loads fine.
Yesterday or the day before (I don’t remember which) I was unable to load the site no matter what I did - my usual workaround of interrupting the page load didn’t work.
