hi, i just wrote this:
https://npmjs.org/package/node-mirror
https://github.com/soliton4/nodeMirror
if you are interested tell me what you think.
if your feature wishes correspond with mine i may give your wishes higher priority.
thx for reading
sol
thx for reading
sol
i fixed it so it runs in windows as well.
i would apprechiate feedback. what do you think - is this something useful?
thx
I'll most certainly take a peek at it during the weekend, adding reminder to my calendar now!
This could be very useful for Drupal!
i have never used drupal but for general web development the integrated less editor might be awesome.
you can directly view your resulting css. the less file will be automatically parsed and saved as .css and there is the possibility to display the less help page in a split view.
are there any hackers reading this? i integraded a hex editor
