Ways to reduce frame drops
Tried out all the offers and to no avail it still stutters and I think I know why. MY CPU HAS NO L3 CACHE. for some reason l3 cache is really important and my laptop is running google chrome with 4gbs ram with like 24 tabs running and it is smooth while browsing.
what did you expect, it's a 7 yearold cpu
I thought it would perform the same as my i5 2450m on the laptop :P
Just wanted to highlight I didn't read all posts (i did some).
But if You're getting issues after you flashed your bios (mobo) then you should flash back to one you had before. Other than that
Limit FPS (you can use msi afterburner) to your refresh rate, this way you won't be overheating your hardware and keep your system from bottlenecks. (enable v-sync too, it might help)
Can't unless if i do some shit do it which requires downloading something other than the bios revision. and a higher chance of bricking the motherboard. Because when I updated cant flash it back due to being ' Image outdated'. My hardware is nowhere near overheating, the cpu hardly goes past 65 the same for the gpu since i have no side panel for the pc that i am using currently right now.
