hey guys!
i was wondering wat is the best between a monsta rad in push or pull configuration an a 60mm rad in push and pull configuration.
hey guys!
If you are referring to the 80mm alphacool monsta rads compared to say a run of the mill XSPC RX series 60mm radiator then they are much of a muchness. XSPC RX series radiators are the best I've ever used, for half the price they cannot be beat.
Depends what you are going for as well - if say you have a case that will look better with a monsta then do it.
