I recently got myself a Corsair h70 with two 120mm Corsair fans, not just the general airflow ones.
Anyway, running prime95 with a 4.1ghz overclock I get temps of around 65-75 degrees after about 20 minutes. I think that is quite high considering I am using a push-pull configuration with watercooling, should I be worried or is this normal?
