Watercooling cases
So I'm looking for my next case for my upcoming build. I really love the style of fractal design but to be honest I'd be compromising on the rad setup I envision. I could go with corsair 900D but it's just to large for what I want. I want something that will fit two 360 rads and a tube res but without an acre of space left over. I feel like I'm asking too much. I haven't seen any retail cases that fit my vision except fractal but they don't have the rad space. Above the mobo is too shallow and I'd have to use a slim rad and I'd only be able to use 240-280 in the front. Any ideas fellas?
So my criteria is
•support for 2x360mm rads
•sleek, refined design (like fractal)
•good dust filtering
•large window
•atx or ext atx
•good cable routing
nzxt h630 is pretty sweet i have one and i fit a 360mm monsta in the front and a 30mm thick 360mm in the top as well as a 240 below the graphics cards (i used a vi gene in mine, so matx gave me that option) cable routing here is pretty beast plenty of room in the back but i will warn you that airflow in this case in general is not the best if your going to do anything crazy with sli then i would say its a no no. its very well built though.
you can get a windowed side panel for it for an extra 30$
corsair 800d?
make your own case.
I was thinking of making my own but I'm not sure if I have the skills. I don't want bolts all over making it look ugly. Fractal Arc XL is almost perfect but not enough space above the mobo and the front only supports 240 rads. If they removed the bays they could fit it in there. Maybe I could mod it but I'd have to lower the mobo and that would be a mission.
2xx360 rads is kinda crazy.
how bout 280's ( 140x280) instead? you are losing about 4000 mm squared area but you'll have 39200 mm squared area compared to 43200 so not a big diff and you'll find more compatible cases, my corsair carbride 300r can pull this off if you mod off the drive bay. which i have.
Yeah, I was thinking of going the 280mm route also. I've basically been researching and planning for about a month now. I have a picture in my head of what I want design wise and I think some of my ideas are going to be really unique as I haven't seen them done before but finding the perfect case is where I'm hitting my speed bump.
The fractal design cases are almost perfect except that they are a bit too shallow on top. In the arc xl for instance, the space between the power supply and bottom of the mobo looks to be about 30-50 mm (estimating from pictures). They could have brought the entire mobo down and gained that space on top. You'd be able to fit a nice thick rad up there.
It's offset so you still could with low pro ram but then you're starting to cover the mobo and crowd the CPU block area which I'd like to be a focal point. It's a little gripe but none the less.
@gaguya
That nzxt h630 doesn't look half bad but the lack of air flow scares me. Have you noticed any temp issues due to this?
Whatever case I get drive bays are gonna go most likely.
mod the case so you can mount the radiator outside the case? or if you're doing push pull, put the pull fan outside the case? good luck.
damn, you can load it up with fans.
Looks like potential. I'm gonna watch some reviews on it later when I'm able.
Wow, I'm drooling over that phanteks case. Might be the best design I've seen yet.
This is one of the coolest cases I've seen in awhile specifically made for watercooling.
http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html
I would love to see Windle or Logan build in this case.
