This is a pair of question for anyone of the teksyndicate team who is familiar with watercooling .
Is it worth it ? Especially for a waterblock on my 8350 cpu
What is the case that you recommend for it ?
Did you have any issues with it like water flotting out of the tubes and giving a nice shower to all your components ?
Ps: Sorry for my bad english i am a native french speaker and actually live in belgium where the NSA is spiying on us ! Oh and last question , does proxy ,like anonymoX addon for firefox , still does the job or vpn is the only way to go ?
Is there free VPN's with DESCENT bandwith ( i was trying one of them and i coudn't load a youtube video at 144p !)
Watercooling is well worth it, both for the performance, and the aesthetics. Noise levels can be drastically reduced, load temps can drop like crazy, and you have so much room to expand. You will always have the noise of the pump moving water, but that is nothing compared to a lot of fans. Different type of sound, as well.
Depends on what you want to cool; if you are cooling just the 8350, you only need a solid 240mm radiator, so pretty much any cases will work. If you want to cool a GPU and CPU, then at least 360mm, just adding 120mm of rad space for each additional component. Also, I need to know your budget.
H20 is awesome. But then to be realistic it does boil down to what you want to accomplish. It is expensive, especially if you want to cool GPU aswell. It also require more maintenance than regular air.
But as brennan sais it has really good benefits if you want a quiet system and just a really cool system (good when overclocking).
As for cases, ATX cases today have the ability to fit a 240 rad somewhere. I would recommend you find one 2x fans in the front rather than in the top (I've had some issues fitting larger rads in the top then colliding with RAM). Fractal Design Define R2 was really annoying on that part.
Personally I have never had a problem with a leak appearing a long time after installation. Most leaks appear in the first minute of filling the system. Just as long as you use good quality tubing and fittings.
Closed loop cooler do not give the same performance or scalability of a custom water cooler, but they have their place. If you plan on going with CLC I'd recommend the Thermaltake Water 3.0 over the corsair coolers, they give better cooling for less money, but you lose some of the sexy that corsair gives.
I've used private internet access, their service is pretty fast. You should try to find one with servers near Belgium to make sure to get an optimal speed.
