Watercooling a Vapor-X 280x
What would be the best way to do a closed loop liquid cooling system with my Sapphire 280x card? Is it possible, or pointless. Looking to change a few things on my build and just tossing ideas around at the moment.
http://www.sapphiretech.com/presentation/product/product_index.aspx?pid=2024&lid=1
Possible yes, nzxt have adapters for their AIO cooler range - G10 bracket. You will though need to have space for the AIO cooler itself inside your case.
Its as easy as getting, 1x G10 bracket, 1x compatible AIO cooler, remove existing heatsink (you'll void your warranty in most instances doing this so beware). Follow the directions for installation of the bracket and cooler carefully. Be sure that there is sufficient contact made with the gpu core and water block.
You'll notice a massive decrease in temps provided you do everything correctly. GPU temps drop like a mofo when under a water block.
Compatible AIO's for the NZXT G10 bracket:
http://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html
The Corsair H75 would be a great match.
Hope this helps.
No , please don't get the corsair CLC's for Kraken , they have 11.5 inches tubing , whereas the X61 etc have more ( 13 i think ) this makes it possible to mount the rad to the back of the case .
By back of case do you mean externally? If so why would one even do that? You'd have to take apart the aio to go through the grommets etc.
Internally the tubing length is fine for rear 120mm fan placement on the majority of cases when the gpu is inserted in the uppermost pcie slot.
No it isn't , I have a R9 290 + kraken and a H440 and it doesn't work without being real tight .
It doesn't reach the front of the case either .
I have looked into the NZXT adapter, my build is currently in a H440 but I am moving to mATX, Corsair Air 240 to be specific. I plan to switch to Intel down the road, but right now I'm just gonna move stuff over to a new case. I bought everything used, so there are no warranties to void.
I was thinking H100i, I need to make sure everything fits before I buy, and that I have everything I need accounted for. I will most likely buy a modular power supply also. Is there a need for a reservoir with a closed loop setup?
Why did you get a vapor X only to put it under water? I feel like its a waste of money because you've already paid good money to get a really good air cooler ... You should have got a stock 280x (if the sell those) and then put it under water.
Before I ordered new parts, I looked locally for used, found my exact build, and got it for a steal. And like I said just tossing some ideas around, no where near close to pulling the trigger. And truthfully the reason I brought all this up is when you go to a smaller case, things tend to heat up. I like water cooling, so I figured why not.
