Hi, i have a GTX 770 and was wanting to invest in water cooling in addition to my existing water cooling for my i5-3330.
I have heard the Kraken brackets and their coolers work well but not sure what is truly compatible with my hardware.
I have a Fractal Design White R4 and a MSI 2GB OC Graphics Card. Is it possible to watercool in my situatiuon? if so some recommendations would be great :D
Thanks, Danny
htps://www.youtube.com/mrdantheman2050 (Dans Tech)
If all you care about is 1080p gaming go for it. Wouldn't invest otherwise. also, you can get a 2nd for cheap for SLI which would be great is you do FPS gaming and need the 140 frame refresh
Hi, Thanks for the info :D
However that didn't really answer my question about watercooling...
karken G10 is a good sulation for the GPU, but imo you need heatsinks with thermal paste for your VRAM.
if you going water best to purchase a water block with a all in one loop system.
or
why not just stay white with 50c under temps for cheap?
http://www.arctic.ac/us_en/products/cooling/vga.html
