Might be that 3M fluid I was talking about but cause COMPUTEX zero info.
time indexed
I thought the Mustang radio build was the coolest part of that video.
I liked the models at the end
Buildzoid has your answer…
oils can lubricate a pump but in this case were talking about heat dissipation.
some of you were describing inter cooler technology immersing the radiator in oil will transfer heat but not as easily as water will.
think oil heaters one of the reasons they are efficient because the oil hold heat for a long time.
cool water serves better than oil
room temp water will cut down on condensation and still efficiently cool the cpu.
we used inter-coolers all the time in the plant for air drier preparations
