Ok so im looking to invest in watercooling my rig later in the year and do some upgrades. My question will these products i've selected fit together. I know the Barbs are the same as the one in the kit just not sure about the blue tubing. Anyone with knowledge of watercooling could you help me out here?
These are the parts but when the 8950 comes out i will get a waterblock for that.
I was looking at compression fittings, changed it to some cheap xspc fittings. What tubing would you recommend for my build instead. I wouldn't mind if i had to change out all fittings for it to work.
