Water cooling supported?
Does the Cooler Master Centurion 6 support a Kraken x40 and a Corsair H100i? Im a noob to watercooling and I would like to cool my computer with water cooling Im just not sure whether this case will support both of these things.
Thanks in advance :)
The case has what looks like adjustable 2x 120mm mounts in the roof, so the H100i should be fine.
The case has 140mm mounts as well, so for a single 140mm Rad AIO unit like the Kraken X40 will be fine. Although they are dual 140mm mounts in the roof, I do not know if the spacing is correct for a dual 140mm rad.
