Ya forgot to mention the res which will be a XSPC 3.5" bay res. I'm thinking the rads will be I just want to be sure and I really have not a clue with the pump situation.
The pump you have listed looks decent and should suffice and as for the radiators I use 120mm rad space for each major component I am cooling as a rule of thumb so you have plenty of cooling. BTW on my previous build I cooled a 3770k at 4.8Ghz, two heavily overclock GTX 680's and my RAM with a 280mm and 120mm rad and temps were good. Also I'd recommend a full cover water block for the GPU's instead of what you have listed. It will cover/cool the GPU and all its memory.
