Motherboard and/or CPU just died (probably due to the dead weight of a Nocturnal NH-D14 hanging off of it for years) so I've decided to upgrade and do it big. Grabbing an 8320 or 8350 and a Crosshair V Formula Z AMD ROG board.
Now, I want to do a watercooling build and don't know only but the extreme common sense basics about it. Here's my shopping list, feel free to critique and add or change items.
CPU block http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_971_498_490&products_id=38326
Res/pump http://www.sidewindercomputers.com/xsd5dubayrec.html
Rad http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_457_667_1075&products_id=34505
Tubing http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_413_292_1153&products_id=36315
Fittings http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_346_393_614&products_id=35262
All in a 900D... I'll worry about a GPU block for my 780 at a later date. Also, I have no idea how much a pump uses for watts, should I be fine with my gold rated corsair 750w? Thanks for reading.
