Water cooling issue
i have this motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813157464 and i don't have a back plate because there's circuitry that would prevent me from using one. i was wondering if there's a water block that can mount to the stock heat sink mount or one that doesn't use a back plate.
i have the same board and i used a back plate anyways when installed my enermax heatsink. was a little wonky but still works
https://teksyndicate.com/forum/build-pc/amd-apu-kaveri-itx-htpc-lego-build/173218
