So, I've had a first gen HAF for a while and I'm soon gonna upgrade some parts but keep my mobo and chip but I want to overclock. I want to set up a watercooling solution for the CPU and gpu and chipset. Now the HAF case has a fill port and plenty of space for all kinds of components. Are there any parts specifically to work with the HAF? I can't seem to find any on the interwebs.
Watercooling parts are not made for any case specifically.
I know that, I guess I didn't articulate myself correctly. I'm looking for a reservoir that would utilize the fill hole on my HAF case. Also a radiator that would work with existing fane screw holes specifically in my case.
I used to have this case and one of the reasons I originally purchased it was to use it for water cooling. Unfortunately I never found a reservoir or radiator that had a fill-port that lined up with the fill-port hole in this case. It's almost like Cooler Master put it there as an afterthought because the ideal location for it would have actually been the opposite side where it's located. If they had put it on the opposite side most bay reservoirs would have been able to utilize it. Essentially you're going to have to mod the case in some way if you want an accessible fill-port.
Time to get out the dremel.
I was looking around for 3 hrs now and I can only find one that almost fits but not quite (as reported by others). I figured with the designed fill port hole there would be a use for it. Silly me.
I'm a watercooling nube but one other question. Do radiators generally instal into existing screw holes? I've read a few post here and there about people having to drill holes for mounting. I don't mind minor mods but I don't want to ruin the aesthetics of the case as I will be proudly displaying it on my desk.
radiators can be slightly longer and wider than fans but they will fit in their respected size fan mounts.
