Water-cooling everything?
Is it possible to water-cool the CPU, GPU, memory and motherboard on a SINGLE custom loop in a micro-ATX case?
This is the design I'm considering:
Reservoir > Pump > Radiator 1 > GPU > Motherboard > Radiator 2 > CPU > Memory > Reservoir.
These are the specific parts I'm considering:
Motherboard: ASUS Maximus VI Gene
Processor: Intel Core i7 4770K
Memory: Corsair Dominator GT 2133 MHz 4 GB × 4
Graphics: ASUS Radeon R9 290X
Case: Corsair Obsidian 350D Window
Cooling:
Bridge Waterblock: EK SB ASUS-M6G
MOSFETs Waterblock: EK MOSFET ASUS-M6G
Processor Waterblock: EK Supremacy Elite
Memory Waterblock: EK RAM Monarch X6
Graphics Waterblock: EK FC R9-290X
Radiators: Alphacool NexXxos Monsta 240 mm × 2
Reservoir + Pump: XSPC Twin D5 Dual Bay Combo
Fans: Corsair Air Series SP120 Quiet Edition × 4
I want to overclock the CPU and GPU, underclock and increase the voltage of the memory to decrease the CAS latency and cool the motherboard components to decrease heat from radiation inside the case.
Do you think this is possible in a microATX case?
Only 2x 240 rads for the hottest components on the market. It would work but don't expect temps to real good one you start oc'ing.
Ram blocks are purely for the epeen factor as well. They were all the rage about 10 years ago, but yeah... Up to you though, I would certainly spend that money elsewhere.
Have you considered the corsair 540 case? It's not all that tall and makes for a real nice WC build when done properly. More rad space (and room for thicker ones which is key), and IMHO once like 10 mins of modding is done to the floor is an awesome piece of gear.
My 2c anyway. It's just in a 350d space is a little tight.
Also, you don't have to break up the loop with a rad unless it is the shortest run. I saw you going to the rad than back to the ram. That would cross things up to much. You want the shortest run. The water moves around so fast that it doesn't matter what  the loop order Is. What's more important is the cooling potential of the rads.
Why on earth are you cooling your mobo and memory? That's just wasting money, just like buyingtwo D5s when a single DDC would be quiter and be more than enough.
