Yea Logan I am the MX8 case is awesome i put the build on hold becase i'm waiting for the massive bottom pedistal to add 2 more EK XTX 360 rads.
For the size of the case it only weighs 17lbs and has multiple config options. Great construction and well worth the money. I did alot of research into buying a case for this build I looked at the new cosmos and it was just way to heavy and high. I looked at the different silverstone cases but none could hold the rads i wanted without modifications. The MX8 is their lowest priced case wich I would suggest to everyone!!
