I need help building a Water Cooled PC under 800 dollars in parts alone...
Parts i don't need added to my list are the following
Monitor
Keyboard
Windows 7
Mouse
PC Case
Speakers
I have all those Parts Mention above. When it comes to the case depending on what Items I need I will add that later.
I been looking around for videos and guides something to get started in building a water cooled pc but cant seem to find anything. There are so many videos out there that you can build a gaming rig for under $800 dollars I understand that but i want one for water cooled. If i can get any help with this build it would be a really big help. I've purchased many gaming rigs that are not water cooled so them all to get an Alienware Mx15 Laptop a few years ago that i use to game around with. IT's time to retire that laptop and now i want a water cooled PC. I under stand fan cooled is probably the way to go. I want to get getting a water cooled out of my system. Im not going to do much overclocking but if there option for that i might.
I play League of legends,Starcraft 2,Warcraft,battlefield... Basically and game that my friends play. I'm not really concern about big FPS. I play most of my Games on High setting on my Laptop Even some games on ultra so I cant settle less than that when it comes to water cooled. If there is no hope for me in this build please let me know with that $800 Price and ill go get a fan cooled pc
Any help is good help ... Links,Guides,Videos,anything that can point me to the right directions id good to me....Feel free to Build me a Gaming pc That would help a whole lot.
I can go over $800 dollars by a little only if i have too
If you're not overclocking, there is really no point to water cooling... especially for under $800
Go with air cooling, no risk of tubing leaking and destroying your rig, no pump noise and a LOT cheaper
if you really want liquid cooling for a low price point, you could go with an AIO liquid cpu cooler, but there is no point in that if you don't want to overclock
watercooling is only really necessary whe you're doing extensive overclocking and your budget is deep into the thousands
A full water cooling loop usually costs $600-$800 so don't really consider it. It only helps if you want to do extensive overclocking. You can get a cool running almost silent noctua Cpu cooler for $60. Go that way if you want to get a cool running, quiet system.
Please don't make duplicate posts - if the site messes up, then just delete the other thread. Deleted it for you.
Copied from the previous thread:
At $800, you should go or air cooling. Some WC loops can cost over $800 in fittings alone, but a bare-bones loop for CPU only will run a minimum of $140 for a kit. Meanwhile, a stock cooler (free), or a sub $50 aftermarket air cooler, will perform more than well enough for you, especially at your budget.
I'm about to get parts in to start watercooling myself. Not cheap, but bought a universal GPU block, and everything else should carry over to whatever I get next. I heard they are supposed to be quieter, but I am going for pure performance. Screwing my radiotar to my desk outside of my case.
Price kinda hurt, but you probably already know buying new is expensive if you are looking into watercooling. There were a couple of other cheaper options I saw online, but figured I better do it right the first time, even if I was paying a pretty penny to do so.
OP will probably spend ~150 on a decent mobo, and ~2-300 on cpu. Somewhere around 60 for RAM, and another 60 for a terabyte sized HDD on sale. I think he might be able to cram a CPU watercooler in there at least.
At this budget, all you can really get is perhaps an AIO or two. I agree with the others that air cooling is much better especially at this budget. If you had 3K, then start talking up a custom loop.
Can always search for used water cooling parts. Saw some kickass prices on hardforum, its like shopping on craigslist though, gotta search everyday, and reply immediately.
I'm not sure how the average water cooler enthusiast feels about those kits, but they look easy enough, and at a somewhat decent price. I'm still waitinig on the mail before I make the switch but I have been doing a lot of reading on this stuff because of it.
